Digimoto
SiNiST3R
347
May 10, 2004
NorCal, California
Hey guys i just got a Digimoto, I am very new at tunning and would love it if someone knows a link on how to tune your afc ect? any advice is welcome thanks. :dsm: I have a 2gen so no knock counting for me.
I was also told to monitor my trims try to get them to about 0. am guess not sure
Adv timing about 17 if i can more likey 15 or so on pump gas
and 02 about .92-.94
thats about it also was told to do a 2k-6500 punch in 3rd.
Thats my knowlege so far.
I don't know what a digimoto is but I've read you want to shoot for 18-22 * advance at the end of your 3rd gear pulls.
Alright, I have just Did a Run. Please put any info on this just to help me get started. I also Cleaned the Log up So it dont look like Garbage for you. Thank you.
010C,Engine RPM 2600
010E,Timing Advance Degrees 11
0110,MAF Air Flow gm/Sec 61.42
0114,O2 Sensor Voltage Bank 1 Sensor 1 .94
010C,Engine RPM Requested 3240
010E,Timing Advance Degrees 8
0110,MAF Air Flow gm/Sec 117.89
0114,O2 Sensor Voltage Bank 1 Sensor 1 .98
010C,Engine RPM Requested 4132
010E,Timing Advance Degrees 9
0110,MAF Air Flow gm/Sec 149.94
010C,Engine RPM Requested 5012
0110,MAF Air Flow gm/Sec 175.86
010C,Engine RPM Requested 5832
010E,Timing Advance Degrees 16
0110,MAF Air Flow gm/Sec 190.71
010C,Engine RPM Requested 6516
010E,Timing Advance Degrees 18
0110,MAF Air Flow gm/Sec 198.81
0114,O2 Sensor Voltage Bank 1 Sensor 1 .96
go all the way to 7k with your pulls. also, can you get any more data points along the way? i also wouldn't worry much about what the O2 sensor says, it's not accurate enough and gives different readings from car to car. just go for a good smooth timing curve at a little lower boost than you plan to run and then turn the boost up 1psi at a time until you start getting timing pulled. once you have it set-up pretty well, go to the dyno and do some fine tuning with their wideband (and your logger of course).
That's the thing that sucks about digimoto/scantool, and anyone else using the ELM323 based interface. It only takes captures of the ECU at maybe 2 or 3 times a second. It's inherent to the hardware unfortunately. I have the same interface and I'm going to spring for a pocketlogger so I can get faster data, or maybe I'll put a dsmlink on my credit card :thumb: Can't beat logging 10 different variables at 20 times a second.
Tallen said:
Ah, the digimoto is just a logger. What are you tuning with?
SAFCII
i did another run with a few changes,
010C,Engine RPM Requested 2052
0114,O2 Sensor Voltage Bank 1 Sensor 1 .92
010C,Engine RPM Requested 2380
010C,Engine RPM Requested 2844
010E,Timing Advance Degrees 10
010C,Engine RPM Requested 3500
010C,Engine RPM Requested 4236
010C,Engine RPM Requested 4980
010C,Engine RPM Requested 5588
010E,Timing Advance Degrees 14
010C,Engine RPM Requested 6212
010C,Engine RPM Requested 6700
010E,Timing Advance Degrees 20
am mainly going off my O2s i leaned it out abit more ill see later how it does should be about .92-.94 now
