Resolved Different stock 2G Fuel Rails? (pics for reference)
RedTurboEclipse
5,613
42
Jul 29, 2002
Bay Area, California
Both were from 2gs. the one on top was from a 95 GSX, the one installed is from a 98 GST.
Didn't realize they were different until I looked closely. As far as I could tell the only difference is the circled areas. Don't think the cars were modified prior to me owning it.
Just thought I showed this for reference, this was new to me.
I did use both and the one above with the open indentation seem to fit the injectors better as it leaves more play for the harness I guess? But other than that was all.
Just one of those perhaps useless but things you may have not known.
Early 95's (1994.01.1 - 1995.01.3) used MD185372, the rest used MD322834.
Regarding MD185372 (which is superseded by MD322834), ASA says:
"The old fuel delivery pipe required the injector support to prevent the injector from turning. The new delivery pipe is of a shape which helps to prevent the injector from turning. This makes the use of the injector support unnecessary."
The injector support is the little clip that holds the injector on.
