1G Did I feed my oil proper?
93xsg
245
55
Jul 3, 2011
Sequim, Washington
Hey guys. Pretty sure I got this right, but it was hard to tell on some low quality pictures from older posts.
Feeding my PTE 6176 (or 20g if I run that) off the 91-94 OFH (oil filter housing)’
QUESTION: is my 90 elbow to feed the turbo in the right plug hole? Looking for the filtered one.
I’m working on the 10an drain as well (waiting on another straight fitting). I have 12an bung on pan reduced to 10an.
On a side note check out my custom oil cooler setup I made
Thanks and comments welcome!
Take a vacuum line, make one slit down the length of the hose and cover that hole the AN line goes through to prevent damage to the lines.
Thank you. Thats funny I was just asking my car buddy what to do about that today, and he said the same thing. Ill be sure to do that. I think theres a few other spots as well.
You can also buy a/n hose clamps to clamp the hoses out away from the sharp edge on that cut out and also take a grinder and dull/round the edge on that cut out. You can see a type of a/n clamp on the passenger side crankcase vent hoses in this picture there are all different types also.
