Dialing in injectors DSMlink v3, need help.
Alpha
34
Jan 27, 2013
St. Augustine, Florida
So i just installed some 900cc HI FIC injectors and i am having trouble dialing them in.
I used the chart on ecmlink website and set deadtime to 330, and changed global to -50. When i do this, it runs extremely rough, and wideband pegs lean, so i changed the setting back to stock, and idle smoothed out and WB sat around 11.1:1.
Does anyone have any ideas?
thanks
Dsmlink should be able to calculate the global you need to use. As for deadtime, the value they provide is somewhat "an estimate." Everyone's car will be different so you will need to change it accordingly. Watch the tutorial videos on ECMlink's website. They are very helpful.
Every car has different conditions. You really need watch the videos. The figures are truly just estimates for a initial setting only.
