Devils Own yellow fault light flickers at wot
Hiitman
482
4
May 12, 2004
Colorado Spring, Colorado
I thought this was causing my knock problem but that just turned out to be a leak at my egr block off plate. The car runs great but my fault light on the controller will randomly flash at wot. I haven't checked to see if I tightened the nozzle too much but I imagine if I did I wouldn't be flowing the needed amount of meth thus causing knock. Has anybody ever experienced the same problem?
Anybody? Chance? I tried loosening the nozzle. Still nothing. Should I turn the pressure down.
I guess reading the Devils Own forum would help. Got this off one of the posts if anyone else was wondering.
the yellow light has 2 uses. It will light up steady when above 95% or higher of the max adjusment of boost. If its flickering under boost then you should probley have it adjust a tad lower boost level.
Yes, if its just sits there and blinks then its an error. This will only go away by removing power and fixing the error
Yea you have the max knob adjusted to slightly above your max boost. When the boost drops down to 95% of where the knob it adjusted thats why it is blinking.
