Devils Own Progressive Controller Questions
AbsolutGS-T
50
May 10, 2010
Vernon, Connecticut
Hey guys, I am in the middle of installing my devils own stage 2 kit. I just have a few questions about wiring in the controller. It says on the directions that the red/pink wire needs to go to 12 volt ignition on, where did you wire that wire to? Also, does the orange wire off of the controller go just straight to the battery? or to another 12 volt source in the car.
Thanks
Where are you placing the controller itself? Personally, I like to run switched power directly to the ignition switch but people have run them to other sources like the cigarette lighter. Only reason I do what I do is to not disturb other electronic circuits as the majority of them are fused and adding additional components might draw too much amperage in one circuit. But I doubt it'll draw anything more than half an amp.
Yes, you can wire the orange directly to battery or any constant power source.
