Progressive controller w/ AEM 5 bar?
HurleyTSi
Regional Forum Moderator
175
Aug 28, 2009
West Haven, Utah
I see more progressive controllers in meth kits use a GM 3 bar MAP as their boost source. But what if I want to run more than 30psi? Or use an AEM 3.5 or 5 bar MAP instead?
I've emailed Devilsown about this but received no reply.
Anyone else doin this? :idontknow:
What email did you sent it to? I didn't see it.
You will want to use our dvc-30 controller that has its own built in map sensor. It will still spray past the limits of what the sensor can read. Your going to want to set the max knob around 3/4-2/3 of your max boost. So this will work find for you as long as your making less than 45 psi. If you have any other questions let me know.
