DanMKIV
- 0
- Sep 1, 2002
Orlando_fl
Any guys using a progressive controller? If so , which one? Im currently about to install a 125hp shot (sportsman fogger) direct port kit on my 2jzge block with all the goodies(walbro pump,purge kit, a/f gauge, nitrous pressure gauge,extrude hone ported intake manifold) . I know this isnt a supra forum - but i figure you guys have a nitrous forum....unlike the supraforums. The kit utilizes the WOT switch - but due to possible traction woes, i am definetly going with a progressive controller....NOS makes 3 different styles (time based, throttle positioned, programmable) - i am not sure which one to go with....i want basically a built in window switch...not to spray below approx. 2800 rpms - and not to spray above my redline. I looked into the crane cams digital unit - but that only works with dry manifold systems. Every shop i talk to tells me to stay away from the jacobs mastermind - so i dont know which progressive controller to go with...any help would be appreciated. Also, would you recommend i go with an aftermarket spark plug, such as NGK 3333s.....they are pregapped..im not sure what gap will be right for this setup.
