kenamond
DSM Wiseman
- 3,225
- 68
- Feb 15, 2006
Los Alamos,
New Mexico
I have a pretty bad boost leak between my UICP (Dejon) and TB. I used an 11gal air tank charged to 60psi and was only able to get about 7psi after 15 seconds on the boost leak tester valve (the valve is a bit restrictive) and would leak down in about 10-15 seconds. Soapy bubbles only showed at the top of the elbow/TB gasket and not the TB/plenum gasket. No bubbles at the compressor/LICP, BOV flange, UICP coupler, or UICP end of the UICP/IC coupler, and I didn't test the IC end of the LICP and UICP couplers (but didn't hear any hisses), but I'll check those again once I can pressurize higher.
The Dejon pipe replaces the TB elbow (didn't realize that until I got the parts), so I had to pull of the elbow and didn't have a gasket.
Anyway, the Dejon TB flange is alot thinner than the aluminum TB elbow flange - only about 1/8" thick.
I'm wondering if I should do something above and beyond the normal call of duty when I install the new gaskets. I was thinking of RTV on both sides of both gaskets, but I'm not sure if that's good enough. Also, I'm not sure how long I should let the RTV set up before I drive it again. I have a POS pickup I can use, but MAN would I like to see what my mods can do with an air-tight intake ASAP!
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Would you recommend that I wait a day for things to set up/harden/cure/whatever with that copper gasket maker, or can I repeat my boost leak test a couple of hours later?
