datalogger help 1st log not good Please help
tsi2fly1991
40
Dec 21, 2003
scottsbluff.ne, Nebraska
I just got my pocket logger and logged 3rd gear run on my 1991 fwd talon tsi
And the knock count is very high can some one look at my log and help
RPM Timing Knock Tps Fuel trim low Fuel trim mid Fuel trim high
5094 8.0 31 100 139 136 133
5156 8.0 31 100 139 136 133
5406 9.0 30 100 139 136 133
5531 10.0 30 100 139 136 133
5688 9.0 36 100 139 136 133
5875 12.0 43 100 139 136 133
6063 11.0 43 100 139 136 133
6125 11.0 43 100 139 136 133
6313 10.0 43 100 139 136 133
6469 12.0 43 100 139 136 133
6719 13.0 43 100 139 136 133
6875 19.0 43 100 139 136 133
7031 20.0 43 20 139 136 133
my setup is a walbro 255lph fuel pump 16g turbo faze boost gauge 2 1/2 down pipe
3'' cat back k&n filter 14lbs of boost 91 octane fuel I was woundering about my fuel trims what should they be new to data logging some one help
Your fuel trims are for part throttle cruising. The ecu corrects the a/f based on these long term trims. You want to be as close as possible to 100%. Anything higher than 100% is showing your leaner than what the ecu expects. Anything lower than 100% is showing your richer. The ecu will compensate untill it can't anymore. 139% is max on the lean side. So the ecu is telling you it can't correct anymore for your lean a/f mixure for part throttle.
Your real problem is the high knock counts at full throttle. I would try to turn down the boost untill you can get it to go down. Drive your tank of 91 down to about empty and fill up with some 93 oct. See if it changes anything.
If it still don't help put some race gas in and see if it still knocks. If it does I would check your knock senser and see if the black goo is melting out of it. Loud lifters will also ring the knock senser.
You need some bigger injectors,afc,and a adjustuble fuel pressure regualor to safely run your 16g. Without some kind of fuel control your not going to be able to do much for your fuel trims.
Hope this helps.
