1st-3rd log, help please
Ganja Man
284
Sep 20, 2003
alright guys i just did a pull from first almost all the way throug third, cant make it all the way because i creep to 20+psi by like 6000 rpms in 3rd (need new mbc). boost is set at about 11 psi right now. so heres my logs
RPMs---------Knock---Timing----TPS-----O2
1781-----------1--------22-----44.9-----.03
2937-----------0--------27-----67.5-----.03
4093-----------0--------26-----61.7-----.03
4906-----------0--------23-----66.0-----.03
6218-----------0--------20-----63.6-----.03
6843-----------0--------19-----10.1-----.03
4250-----------0--------29-----85.1-----.03
5250-----------5--------18-----99.6-----.09
6343-----------27-------13-----97.2-----.17
6625-----------43-------9------67.1-----.13
4687-----------11-------14-----99.6-----.46
5187-----------10-------16-----99.6-----.60
5781-----------26-------15-----96.4-----.70
6218-----------43-------9-------19.9-----.76
my mid and high fuel trims are at 100% and my low is at 90.6%
ok so it seems like im knocking pretty good in 3rd and my o2 voltage seems to be outta whack. im using a maft and everything is at the base setting. any suggestions? thanks
