Data Log
MiSFiTz
56
Jan 5, 2004
Chillicothe, Ohio
Aight heres what i got... a car not running right.. just put on 660's and a safc2 walbro 190 is going on monday.. evo3b16g fmic bpr7es plugs magnacore wires balance shafts gone and more...
Lemme remind you this is just sitting at the house reving it...
97 TPS
4520 RPM Couldnt get it past it cutting out.. so i quit
Vehical speed 0
Calculated load 45% it stays at 19% at idle
Ignition Timing Advance 33 5 at idle...
short term fuel is 17
long term fuel is 3
Air temp was 136
Coolant temp 213 on this.. 163 at idle
oxygen sensor 860
Oxygen sensor 640
Ill try and get one driving to work tomorrow and post the actual log itself to be looked at..
WTF is going on here?
You'll have to figure out how to post the wot portion of your datalog in a numerical format.
What are your safc settings? How much boost? Have you checked for boost leaks? Does the car run right when the engine is idling and cruising?
Yeah might help to add that info huh.. LOL
The safc settings are around like 14% - on the low and like -22 on the high.. 4 cylinder w/ the arrow pointed up.. karma setting duh, 3% correction, 30 and 80% setting....
Boost leaks none, car drive fine if im belows 4000 rpms and not trying wot...
Idle is perfect just a putter here or there but thats normal on dsm right.. LOL
Im running 8lbs until i figure out wtf is going on...
