Danger in starting car without harmonic balancer for a couple of seconds
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
I had a metal tapping noise coming from timing belt area so I removed all the covers and belts and started the car for about 4 seconds without my fluid damper pulley. Any damage done to motor in those few seconds while I tried to pin point noise or I ok?
It turns out the noise was from the timing belt cover because I didn't hear it after I removed everything.
As long as you had the center bolt in, and the timing belt did not slip you should be just fine.
Awesome guys. All timing belt components was on and secured.
Only removed the 4 bolts for crank pulley and timing belt cover!
Whew! Thanks
Although I am pretty sure you did not do any damage and you are going to be OK., but why if you had any doubt , did you not ask before hand and saved yourself all the sweating and worries.
If more people did the asking before hand, I am sure they would save a lot of head aches and money
It is just like signing a contract and taking it to your attorney after the fact.
Would this site even have existed then if we all thought like that ??? Lol I get your drift, I got a little impulsive.
It would have and maybe with a lot of people with more money in their pockets.
The knowledge in this forum is unprecedented, and should be used more by its members before they screw up, and ask for advise later.
Anyways glad you found your rattle.
