cylinder wall problem
You can't bore it to 2.3l you have to stroke it. The most you can bore is To 87.5mm. Stock is somewhere around 85mm
ok guy's i found a use motor my mechanic call me and he toll me that he call to a chunk yard and he found a 97 mits gst with 52,xxx thousand miles!!! so what all you guys think should i take it and if so what are the first things should i need to check or change ??? any advice are welcome Thanks:thumb:
