Cylinder Bore streaks
half-cocked
466
Aug 29, 2004
Bullhead City, Arizona
I was putting in the #3 piston tonight and when I pushed it down the bore it streaked the bore all the way down. Didn't happen with the #4 piston and I didn't do anything different. When I run my hand over it I can't feel the streaks but they are very noticable. How bad will this effect ring seating? I'm using .020 over Ross pistons with Ross rings. I need this on the road like yesterday and taking it back to the machine shop is not an option. Any help?
Sounds like dirt during assembly. If you can feel them with your fingernail, you'll probably burn oil.
You already know the one right way to fix it, sounds like.
Your dice, your throw.
Well I pulled the piston and found out that my gorilla ass broke the end of the second ring while putting it in. The pistons seems fine, one small nick on the second ringland. all other rings are OK and I got another set of rings that I accidently ever endgapped. The second ring was overgapped by .0005" but I am going to go ahead and use that and pick up a honeing stone from Checker and hone it myself.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
