Alex7747
- 1,047
- 5
- Sep 27, 2010
Hesperia,
California
Okay so i found some cylinder heads in the junkyard the other day and i was woundering if they fit. I have a 2g 7 bolt. I found a 4g64 off a galant that looks like a direct fit but not 100% sure. And a 1g 4g63 N/T 7 bolt head. I know that 2g heads are the ones i want because they flow more air. Also i was going to get the 1g throttle body from the 1g and bolt it on to my intake mani. Would that fit or should i get get the whole intake mani from the 1g? one last thing i want to run the cas from from the 1g and 97-99s. I have the one that goes under the intake cam gear. And i want to up grade the cams and cam gears. Would i just buy the cas adapter that i always see on here?? Or is there more involved? Sorry for the long post.
Thanks for the help.
