1g Heads to 2g Heads HELP!!!
nightstocker99
241
Aug 2, 2005
Saxonburg, Pennsylvania
I recently bought a set of 1g heads off of e-bay but I lost the item description and the seller has changed his e-mail address or something. I was wondering if their is anywhere on the heads that will help me to identify which style of heads i have. What I am planning on doing is putting the cams from 1g and putting them on my 2g block. then send the heads to get worked on. So it would also help if i new all the mods that had to be made to the cams in order for them to work right in the 2g.
Thanks for the help. :dsm:
So just to get to the point you need to know what to do to 1G cams to make them work in your 2G?
If that is your question I beleive that the intake cam needs to be tapped for the sensor.
that is a little confusing to me. what does the crank sensor have to do with the cam sensor and also does this mean i need to go and buy a 1g crank sensor.
Is it even worth placing 1g cams into 2g heads or should I just gfet some HKS cams and and gears and call it a day?
You said you had a 1G CAS and wanted to know if you could use it in the 2G and I sent you directions on how to.
Correct me if I'm wrong, but aren't the cams virtually the same between 1G and 2G? Also you better make sure you have a turbo head, because the 4g63 non-turbo cams were quite a bit different. It'd actually be a major downgrade in your case.
Are your cams not working or do you think the swap would be beneficiary?
my cams have lines dug from a rocker getting stuck. I think you only get a few horses out of the swap. but i own them and does really feel like waiting to get HKS cams.
that why i asked:
"i was wondering if their is anywhere on the heads that will help me to identify which style of heads i have."
if anyone know that then that would clean up that question.
What is the intake size? Measure it, that will tell you. Here is the inverse side (the intake manifold) the 1G is larger and to the left.. this should give you an example to go by.
Also RRE has this tech guide for installing a 1G head on a 2G
RRE's Eclipse 2g Turbo to 1g Head Swap Tips
Thanks Man!
