2G Cutting out before boost?
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
Mods: Speed density, 1200cc injectors, e85, hx35, fp2 272 cams, black box ecu, iac delete, isc delete
Upon Taking off from any stop, the car starts bucking unless you give it lots of gas. It reads a regular 14-15 on the wideband, then will randomly fall to 11, 10 and sometimes even 9s, then start stuttering like crazy, as soon as i build boost it goes away, and pulls really good. This happens during regular driving as well.
It seems to only be an issue pre boost. Im thinking the coil might be shot, but looking for any good options here as the car cant be fine tuned unless the issue is resolved.
The wideband starts to fall on take off? Seems like it's drowning in fuel if it goes to 9's with no boost. It could be a coil but with that info I think I'd start with looking at fuel. Just my thoughts, it always something holding up a tune :|
Could be bad plug wires...when were they last replaced?
Sad part is, just recently it was running fine. They are old but, 9mm racing wires. Something to look into
If you want real help, fill out your profile with a comprehensive and complete mod list. We don't even know what car you have.
I am having the same prob... preboost no power stutters and stalls. after 3000 rpms the car boost fine and pulls hard. I'll be updating my mods list shortly which I haven't updated since 2009. I'm definitely going to be watching this post closely to see if you need anything
post mods here
Base tip in needs adjusted at right before you spool its going rich because its giving to much fuel in spool and then your getting the rich fall on the face feel and then bam good because you have enough airflow to straighten it out. I would check for pre turbo leaks also
I might have found a solution. After doing some research on here I stumbled accross a thread with a lot of members having the same preboost break up and stuttering issue. After going through the thread, I found a post that basically recommend to clean the injectors. I decided to give it a shot and voila!!! No more break up and stutter. I picked up some carb and throttle cleaner and built an injector cleaner just like the one Jafro made on his you tube channel. I used a double A battery to pulse the injectors and it worked flawlessly.Give it a shot and let us know the results...
That's awesome. I just watched the jafro video. I didn't realise it was that easy, I've always sent them out to be cleaned at a local place for 15/injector. No more!
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
