FLIPTION
- 41
- 0
- Nov 11, 2002
EAST BAY,
California
so i want to be able to avoid cops w/ out a shiny exhaust, pass smog in CALI (keep stock cat), and exit all this air at the same time. Figured one of those electric cut outs would work. Now, should i juss cut out my stock downpipe or get an aftermarket one (bigger diameter) and cut that? or would it be fine w/ the stocker? i'd like to get a bigger dp but i can't seem to find one that'll bolt onto the stock cat. Most ones i see eliminate the cat. Sooo.. think I should continue looking for one, or juss make the cut out on the stock downpipe? Would there be that big of a difference w/ the stock than say a 2.5inch w/ a cut out? Thanks.
. The S-techs have been great drop wise. Though I think I will probably change to Eibachs or a who other setup eventually just to get some stiffer spring rates, but if you just want it for lowering, they're nice and ride well with the illuminas.
