Boomdeeze
- 2,146
- 395
- Jul 5, 2009
Independence,
Minnesota
When I was dropping my rear sub frame to install my new rear end, I broke the grade 10 bolt that holds the control arm to the U shaped bracket. I was forced to cut it the bolt on the sides to drop it and then tried to drill out the bolt that was seized inside the bushing which was a failure. So I cut the old out with a saw-zal and did some improvising to fix it with minimal amount of money.
I had an old poly-urethane tranny mount and had a brilliant idea, tell me what you think!!!
