mitecl96
- 460
- 9
- Feb 20, 2012
McMinnville,
Tennessee
OK first off I'll start of by saying I searched. Really wish I didn't. The stupid things I have read SOME 420a guys say. I can see way not many people take us serious. I will say I am committed to my car as bring a dd. I will buy a GSX later when I have the space and more income to make it the way I won't.
In the end I want a reliable dd making around 300 HP. My goal to make this is to turbo of course. The build is going to be done in stages. My first stage is going to be starting soon which is to have megasquirt as a complete standalone. Going to be running MS3 with the MS3x board. Going to run coil over plugs and have sequential spark and fuel.
The next step is where I need help. It is to build the block to hold up to what I need done. I have this mostly figured out. I just need to build the bottom end. The top end I've been told and read it should be fine with 300 HP just to freshen it up.
I'm going to use eagle rods but my question is I do plan on turboing the car but will be later on down the road. I know right now the only compression ratios I have to choose from is either 8.8:1 or 10.5:1. I don't want low compression because that will suck without a turbo. I know high compression will give me more engine power but is harder to tune when turboed and have to run e85. I still want to run regular gas 91 as it will be a daily driver and will sometimes have to drive 1000 miles to visit family.
So I was thinking to get custom pistons that make stock compression so the engine will still drive like normal and can handle the power when turboed. How much or custom pistons going to cost me and has anyone done this? I had a friend tell me why not buy the high compression pistons and have the shave the piston head to lower compression. I have heard of this but I don't know about this, I wouldn't want to spend money on pistons and then have them ruined.
I also want to add that step 3 is to turbo the car. The turbo I plan on using is a turbonetic T04B stage II super-v .48 A/R that will be water cooled. I am not sure about how much psi I will be running because not sure how much is needed to make my power goal.
Sorry if to much information just want to make sure you all have as much information to better help me.
