Custom FMIC piping?
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
Just out of curiousity, who has built their own fmic piping? For those who have could you give me a general idea of how hard it is and how you went about it?
I will be once spring hits. I'm pretty sure of the route I want to go as far as buying/fabricating piping. I'm fairly sure I'll be buying mandrel bends from Jegs or Summit. I'm not sure about the passenger side, though. I might just have that bend made at a muffler shop rather than try to piece together the bends for it. It might be cheaper. I have to do some measurements and then I'll know where I stand on it.
If you already have an aftermarket UICP, all you need is to get 2 180* mandrel bends from Magnum Force (you would probably want the 2.5" 6" radius bends found here )
You may also need a 2.5" straight exhaust pipe found from Autozone/Advance Auto for a mere $3.
I hacked off the 90* bend on my aftermarket UICP and flipped it around facing the other way. Then, I took the whole pipe and made it face the front of the car with the new 90* bend facing the 180* bend coming from the passenger side of the intercooler.
Its kind of hard to explain, but I ended up only spending $50ish on pipes, couplers, and clamps for my FMIC setup.
heh i have a feeling that im going ot be pming you quite a bit haha
Get a downward firing turbo, my 16g's piping makes me want to strangle someone. Almost every j-pipe made goes towards the passenger side instead of the driver side, which causes most 90 degree bends of any normal size to not fit well/hit the front motor mount.
Go for it, I get alot of PM's about my set-up. I encourage those who are trying to do the same to get ahold of me. I like to do things right, but at the cheapest cost possible.
For 2gGSX, J-Pipes go straight down. The lower IC pipe changes the direction of airflow. If you have a FMIC with one of the upfiring Mitsu turbos, let the J-Pipe downfire, then route it with the lower IC pipe to the driver's side of the car.
I'm trying to get this done with all hard pipes. The thing is the J-pipes don't go straight down it bends a little towards the passenger side. I'm thinking a tight 90* 2" pipe or coupler might solve all my problems though. If I need some more ideas I'll give you a PM with some pictures.
When he says it curves towards the passenger side, he means like this:
This puts the pipe opening on the left side of the motor mount, directly beside it. Like this:
To get past this issue, I'm using a 45* coupler angled towards the radiator, then to my lower L-pipe which will be turned towards the driver's side. The L-pipe is going to run really close to the AC fan shroud, right under it. I have the RRE J-pipe that comes with their install kit. I rather wish I had a different one, but I'm not going to buy a brand new J-pipe when the one I have will work fine with just one more, albeit one more expensive, coupler. We'll see how it all comes together next spring. :)
Either find a shop that has a beading tool, weld the beads on the outside, or use some JB Weld if you're super cheap. :) The beading tool is super expensive, so you're average shop won't have one.
I absolutely love the "Quicksteel" and "Waterweld" quick setting stuff for making beads. Just run a bead around the end like it's play-do and massage it on there really nice. Mine has held up for well over a year without any problems.
