FMIC Piping?
AtlanticGSX
30
Jun 25, 2010
Wilson's Beach, NB, Canada
Will a Standard Piping kit work for a 14b swap 4g63? the fmic i purchased from a user on here is a side to side in/out. Unfortunately, something I didn't think of when i purchased the FMIC, was how it would mount and to what? Feeling a bit foolish now, but as I have already purchased it I feel I should educate myself on the matter and go with it. Any help, pics, links, or specs would be helpful. Just in case it helps, i measured the FMIC. It is as follows:
Total Legth between inlet/outlet is 27".
Length between possible mounting tabs that haven't been drilled 24"
Height 6.25"
Thickness 3.5".
If necessary I may be able to take come pictures and figure out how to post them. Thanks in advance for any help!
Yes the universal piping will work, however you need to obviously cut them to length and bead the ends to keep from blowing couplers off.
I recommend finding pipes that fit correctly so you have the correct lip to avoid couplers blowing off. Do a google search; you can find just about anything you need.
