Curious about how compression test works
juntjoo
780
Sep 12, 2011
fort myers, Florida
Since 1/2 of each engine stroke a valve or two (not quite sure how the valves are set up in either SOHC or DOHC) are open, during a compression test, how do you get any compression. Be nice. Remember I'm in the newbie section. ...oh dang, the other 1/2 of each stroke? Did I just answer my own question? Am I almost out of the newbie section?
Sent from my SGH-T989 using Tapatalk
Compression testing is simply threading in a tester in the sparkplug hole.
You unplug the MPI fuse so the injectors won't be squirting fuel in the bores when doing this test.
As you crank the motor, compession is is read by the gauge per each compression stroke and is displayed on the gauge in PSI.
Trick in reading is looking at the gause when the motor is cranked where the needle is displaying the compression. There is a button on the side of the gauge which locks the needle when the highest compression reading is reached so that one can stop the motor cranking (only takes a few strokes) and document the reading.
Ah, the compression stroke, HENCE the COMPRESSION test. Well apparently I have ZERO compression. Okay thanks people.
Awesome vids! Thanks. I like Eric the car guy. Already used a few of his vids.
