Cruise control
kspharris
478
5
Aug 9, 2005
Goodlettsville, Tennessee
Hey all. My 91 2.0l n/t auto cruise control is not working. The switch indicator turns orange when turned on and when I push the button the green light on the dash comes on but it doesn't hold any speed. The only vacuum line I see is connected. My throttle cable is loose and I did tighten it but it didn't help. I had to loosen it back up after a couple days of driving because it was sticking and holding the throttle at about 1400. I just got my logger going again and it shows 86% at the floor. Now if I press super hard on the tip top of the pedal I can get it to 91%. Is there a problem with my cable system? Is that affecting my cruise control? Where should I start to fix my cruise? Thanks everyone.
The cruise has a small vacuum pump mounted just below the control valve. You will see a small vacuum line running between them. When I get to work ill see if I can pull up a wiring pin out so you can check if the pump is working.
  • For sale NEW Magnus Forged Transfercase gears
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
