Cruise Control
undefined0000
1,073
Sep 2, 2012
Findlay, Ohio
Alright, I've looked and looked and can't understand the vacuum diagram, so here it goes
This unit:
Has a line from it going to here:
and a vacuum hose pictured here:
Where does it go?
I have a "T" for my boost gauge that I could use if it won't break anything. The cruise control worked before we took the intake manifold off, but now it doesn't and I'm sure its because of this. Thanks guys. If you could even just point it out on the vacuum hose diagram, that would be fantastic.
That line should go on the end of the actuator in the first pic. The other end of the hose should lead to the vacuum solenoid for the cruise.
Where's that solenoid at?
Never mind. Found it, cruise works now, thanks a bunch!!
