ECMlink Critique my DSMLink logs
gsxtasy
859
19
Oct 17, 2002
Lincoln, Nebraska
Hey guys, just got a few logs of the ol' dsm. Throw some suggestions at me. Quick mod list: ported 14b, ross/eagle 6 bolt, 1g head/intake, fmic 2.5'' short route, 3'' exhaust as of this log its was on stock fuel setup. 91 octane
thanks guys!!
-aaron
If the boostest is right your running 16psi, so I would say if thats where you want to stay than lean it out little at 6.5k to redline. If that take away the knock than start adding more timing. Do you have a wideband, if not I wouldn't go much further without having an exact afr.
30lb/min is way to much for 16psi on a 14b. I'd check for a boost leak.
I was seeing 28-29lb/min on my old 14b on at 22psi droping down to 18psi by redline on M7 meth inection system at 19-22deg timing. You really need to invest in a 3.3bar map & pigtail for $89. It's the best tuning device for dsmlink for the $ peirod & seeing that you don't use your MDP sensor anymore with that 1g intake manifold you have no reason not to get it :)
Hey, ya i was wondering about that... 30-31 seemed like quite a bit for a 14b. I will have to leak test it again. And i'll go look into the map and pigtail, anything that'll help! thanks!
I'll save you the trouble.
Sensor:
GM PART # 9373269
CATEGORY: Computer Control Sensors
OUR PRICE: $50.49 (Gmpartsdirrec.com)
DESCRIPTION: TURBO PRESSURE SENSOR
PigTail:
GM PART # 88987997
OUR PRICE: $16.31 (Gmpartsdirrec.com)
DESCRIPTION: CONNECTOR
http://i18.photobucket.com/albums/b122/scottsee/Website/full.jpg
Thats the same sensor that you listed twice isnt it? LOL Do i just wire it into the old mdp sensor or how does that work. sorry such a noobish question, just havent researched much on the map sensor.
Yeah, sorry. I didn't notice I did that.
Unplug the MDP harness from the sensor, splice the harness and solder on the weather pack, then uncheck the Evap/EGR/MDP box on the DSMLink DTC dialog.. Good to go..
GM 3bar pin A = MDP ground (Black)
GM 3bar pin B = MDP signal (Light Green/Black)
GM 3bar pin C = MDP +5V (Green/Yellow)
How about you post a log where you're going WOT. Your rpms drop and raise like crazy.
