Idle, cruise, and WOT logs. Please critique.
CiscoBite1Time
304
8
Jun 26, 2002
milwaukee, Wisconsin
I know for sure I need to recheck my WOT 3rd gear pull but I don't want to keep going WOT if idle and cruise are not up to par. I'm baffled as to why at WOT i'm only at ~ 75% throttle position. I will need to recheck my new non cruise cable I just put in.
Any pointers will be appreciated.
Thanks.
I can't update my profile or add a signature for some reason. Here's my car info and mods list
1998 TSI AWD
Stock rebuilt 1g head
-HKS 272 cams
Rebuilt 1g block
-Ross 8.5 pistons
-1g big rods
-BSEK
PTE 880 injectors
Rewired Walbro 255
Aeromotive AFPR
Turbonetics 50 trim
Turbonectis exhaust manifold
Turbonectis 38mm WG w/ ex. dump
Megan 3 inch TBE
VFRS FMIC
90 style OFH w/ ex. oil cooler
LC1 WB w/ gauge
Autometer boost gauge
Autometer oil pressure gauge
ACT 2600
Stock flywheel
Street disc
DSMLINK v. 2
Wow, nice mod list. Do yourself a huge favor and upgrade to v3...
From the log, the tps shows it's hitting ~90% It's weird though because it looks like the tpsvolts are dropping off throughout the pull, so this could indicate something mechanical, perhaps the cable like you said.
If that doesn't resolve the issue, you could try using the tps adjust tool in link or perhaps a manual adjust will be needed. Maybe the tps isn't secure :confused: Manually adjusting basically involves zeroing out the tps offset in link, loosening the two screws on the tps and then adjusting until Link reports .63v at rest.
First rule of tuning is resolving mechanical issues first and foremost.
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
