All my logs -wot-cruise-idle...one thread instead of a ton
yeti-gvr4
422
Dec 23, 2010
san diego, California
so im desciding to make one thread for all of my logs so i dont have to continue to repost or put in a thread that no one views because of a misleading title.
so if you would like to shed some light on how my logs looks i would greatly appreciate it.
so to start heres some wot logs with idling at the begining and end
I CANT put LOGS in TO THIS THREAD BECUASE i previously out them in this thread.
after those logs have been reviewed il start posting my new logs in here
.http://www.dsmtuners.com/forums/log-file-advice/405306-idle-log-why-did-i-stall.html
ok so i had a bad knock sensor and got another one and also switched to my 1g maf so i did some pulls up and down the street and my wastegate actuater isnt working properly as i boosted to 20psi on wg pressure, so i connected the BCS and i boost 14psi tops now. i usually dont really get any knock now but i still did see some degrees during the WOT pull and also when ever i see my CEL FLASH I let off the throttle just wondering if you guys could review my log and see a reason for this knock to appear?
i am on the STOCK TIMING TABLES
