thekyguy11
- 115
- 3
- Oct 4, 2004
H Town,
Wisconsin
Hales Corners is about 20 minutes southeast of Milwaukee.
Nicely said indeed. For the most part, this is what we did. However, I dont think you understand exactly what happened with the clutch.
I worked on the clutch issue for almost two weeks! I searched for answers online, called SBR, called Fidanza, started a thread on the dsmlink forums, and i even started a dedicated thread on here. Unfortunately, I found that people have a whole range of different solutions for that problem, and it was very difficult to determine which one was considered doing it "right". I'm not sure where you read that we over tightened the clutch. I tightened it to spec, and after I installed the tranny, discovered that it wasnt tight enough (the pp wasnt butted against the flywheel completely). I read that someone else had the same problem and remedied it by tightening his pp beyond spec, as that is what was needed in both his and my case.
As for the shim, I believe that the thrust bearing damage must have already begun by this point (from over-adjusting the travel of the master cylinder actuating rod) because when I checked the spacing of the release arm in the hole in the tranny, it was off center. One of my sources of information stated that an off center release arm calls for a shim behind the fulcrum to compensate for a worn fulcrum and release arm. What I didnt realize is that it was off center because the thrust bearing was already on its way out the door by this point.
I agree with your philosophy completely. I understand we made mistakes. As of right now, I believe we built the entire engine correctly, and the clutch issue quickly destroyed it in a nice, expensive, chain reaction sequence. I appreciate the advice, but just know that we pretty much were carrying out this build with that philosophy already in mind.
Here's a recommendation for you guys though that are still building the 'monster'. Post your problems before you invent the solutions. I cringed when I read that you 'overtightened the clutch' and 'shimmed the fulcrum' knowing that you would get problems, and sure enough it happened. If you get to a stopping point; stop! Then get on the board and get some advice or make a phone call. Hell, if you need someone to point you in the right direction, just stop trying to climb the learning curve with a full-weight dsm on your back, and take the metaphorical escalator built by the hundreds of DSM enthusiasts who have paved the way. Turn this thread into less of a cautionary tale and more into a description of your learning process.
. Great work on the car, amazing persistance, and great video. I can't say how envious I am of you guys right now
. I forgot it was pumping gas in that whole time. After that, she fired RIGHT up, ran smooth and relatively quiet (lifters still need to setup) and warmed up to normal operating temp. Even idled fine (which it never did)!!!!!!!! Now I need to get my wideband fixed before we take her for a spin and break in that fresh motor.
