LiquidX
DSM Wiseman
- 8,280
- 132
- Sep 19, 2008
Anywhere,
Pennsylvania
I've been out recently using Eric's (Turbosax2) Excel spread sheet to dial in the VE tables for WOT so they are going to be closer together after this posted log.
I am now getting an insane amount of knock and I just changed up the fuel and timing tables to have a variable amount the ECU can go through. To me, everything seems fine but something is obviously amiss.
I can't seem to do anything to get rid of this knock unless I run 15psi or less.
The attached log is a quick 2nd into a 3rd gear pull. I just activated my EGR to run my meth pump and when it supposedly kicked on, I didn't see any changes in the AFR. It's -20 washer fluid for the time being until I get these issues figured out and mix up my VP M1.
I pulled the line from the check valve for the meth nozzle and fluid did come out so I'm assuming it turned on. I did take notice that the mixture that came out hit the block by the t-stat housing and started to boil instantly. I also have some wire loom melting into a puddle on the power steering pump. Manifold is wrapped, part of the down pipe is wrapped, and my o2 housing is wrapped minus the waste gate itself. All that's left is a blanket for the turbo.
Any help and advice will be awesome!
