audiodan
- 0
- Apr 25, 2005
Huntley,
Illinois
My car has a 2100 clutch with about 50k miles on it. I've driven the car alot over the last 2 months (just bought it and being summer and all) and the last week or so I've noticed about 9 out of 10 times after letting off the clutch pedal it comes up smooth, engages about 1/4 to halfway off the floor, continues up then stops about an inch from the top, then kinda "pops" up that last inch. The car really doesn't "launch"... but still takes off ok in first. The other day when I drove it last, I was on the tollway and a couple times while in 5th when I hit boost it basically revved up and didnt really pull. Since I've owned it its never pulled when I downshfted and had it revved past 4k and engaged. Now I'm pretty sure this all points to needing a new clutch disc.. but I'm alittle paranoid about crankwalk. I've never noticed any problems with the clutch petal in turns, but then again I've haven't actively tested this. I have noticed some "ticking" noises coming from the engine but only at idle and it sounds like its coming from the injectors and not down by the crank. Basically the slight "pop" in the clutch that last inch has me thinking too much.. I just need some opinions. Thanks
