DiamonDSM98
Supporting Member
- 25
- 4
- Oct 2, 2017
Detroit,
Michigan
Problem Solved...the plate between the crank sprocket and balancer sprocket was on backwards. I looked at the other block and noticed a difference in the plate. Sure enough, as soon as I flipped it over everything lined up. Note to self, make sure to install the plate on the right way next timeThanks for the hints and help guy
Let’s say I’m having this same issue. Would I be okay to make my own mark on the crank pulley of the plate was installed backwards ?You might have that litte shield that goes between the balance shaft belt/sprocket and the outer one for the timing belt on backwards...if it is, you'll be off on the inside mark, which will throw the outside mark off. Also, if that shield is backwards, it will chew the timing belt up pretty fast. Pull a spark plug, use a screwdriver as a "feeler" and get the motor as close to tdc compression on #1 cylinder as you can..watch the screwdriver go up and down..you'll come really close to absolute tdc doing it this way. THEN look at where your crank pulley is at..but if you're that far off, all the rest will line up fine, and the crank is off 30 degrees...if the shield isn't on backwards..the tdc trick will tell you
Dave
