crank seal not seated right
TimF
821
7
Mar 14, 2011
Aurora, Illinois
I noticed today after re installing everything that the front case crank seal has a small lip that didn't seat right against the crank. I am wondering if there is a way to fix this other than tearing everything off and having to order all new gaskets ect all over again.
it was, and I oiled it. It must have got caught somehow when sliding it over the crank shaft. is there a way I can wedge it back in carefully so I dont have to tear everything apart again?
Grab your feeler gauge set, use like the .005 blade and push the inner lip into place.
It is a double lip seal, just like the rear main. It just happens from time to time.
I completely forgot that that the end you push in to. might be a pita to remove with the crank in the way. I was thinking you have to take it out from the other side. Ill try it with a feeler gauge first if that doesnt do the trick ill try and get it out.
