Crank pully is squeeling
Cali2gGST
Mar 7, 2007
Simi Valley, California
Ok well last night after a 30 mile cruise to log close loop on my dsmlink i got off the freeway and went to shift and my clutch pedal went very soft and i had a bard time getting into gear. so then i tried shifting again and this time i heard a loud squeeling noise as the clutch pedal was pressed all the way down. So I finaly made it home i thought it might be the idler pully and or the belts so to try and trouble shoot it i removed all three belts ac ps and alt. then i started the car and the squeeling is sill there it sounds like it might be the crank bully but i dont know could it be somthing in the blance shaft? or timing belt pully? i have already bleed my clutch and its doing the same thing with the squeeling but the pedal is stiff again like before it is no longer laying on the floor. i will update my profile right now with all my mods
7 bolt
850cc fic
fp2 cams
fp race mani
turbonetics 50 trim
rre clutch
b&m short shifter
ecmlink v3
Gm 3 bar sensor
aem wb with gauge and wired into ecu for logging
aem tru boost set at 21PSi
running 100oct
symborski shifter bushings bearing in under hood shifter linkge
i run royal purple 10w30 change ever 3500\mil
walbro 190 fuel pump
type s BOV
aluminum evo shift knob
yokohama advan neova AD08
just re did all grouning wire with 2 gauge
AGP wastegate
new front nb 02
new wb o2 in the rear
i think thats all
How many miles are on the engine/transmission? If the squeal is associated with the clutch, it sounds like a throw out bearing. Also, does the crankshaft move in/out by hand or when you press/release the clutch? It could be beginnings of crankwalk. But, don't panic yet. Check your crank pulley for splitting like 91DSMDave said.
theres about 95k on it. there is no play of the crank in or out or side by side. which way did it crack along the grooves? or down the middle?
what wierds me out its been runng great!!! the last couple months i had even recently fixed some startup/ideling issues that were o2 and dsmlink settings and it starts and idles like a champ even with the squeeling it has not affected the idle/startup
would posting a log from when it started acting up last night help at all ?
if so how do i post a log?
It cracks on the rubber insert betwen the 2 pieces. The pulley is actually 2 different one's with a rubber insolator between them.
great thanks ill check it out and update u guys in a bit
ok so ive checked out the crank pully and its fine i even removed it and inspected it. then i used a rench to turn over the crank and i can still hear the noise. any oother thoughts or ideas/?
anyone in the simi valley area care to come by and take a look
