crank pully
lou schmouder
271
Jun 17, 2008
dalton, Georgia
which way do I pull my cheater bar toward the front or toward the rear????? dont wana snap this bolt
Are you talking about the big bolt that holds the timing gear on? It's regular thread--Righty tighty, Lefty Loosie.
That's really not very descriptive.
If you happened to have the breaker bar pointing up and you were pulling to the front of the car you would be trying to loosen the bolt but if the bar was below the centerline and you pulled to the front the reverse happens.
its got for but need to take timeing cover off to check for oil leak. do they make a non ac crank pully????
