crank pully
killab443
602
3
Nov 24, 2003
Howell, New Jersey
when you turn the crank pulley to btdc should the cam marks line up? I did a timing belt change and lined all marks up. now I put the crank pulley on and line it up to btdc and the cam marks dont line up at all, am i doing something wrong>?
Crank it around a few times (by hand) and see if it ever lines up... you may not be on the right stroke. If it doesn't line up eventually, you need to re-time everything.
i took it all off to find out that i cant be on the wrong stroke because of the timing plate on the crank sprocket one full rotation brings me rite back to were i started
Thats right the cams turn once every 2 turns of the crank. This means they are in the same spots for the marks just that the dowel pins rotate from top to bottom. If all the marks don't line up it is a timing problem. Hope you didn't bend valves and you just need to redo the timing belt.
Always use a straight edge to make sure the cam marks are in a perfect line when timing the cams.
how could i have bent valves. i turned the crank with a rachet a few times when the timing was wrong, it came out to be about 5-6 teeth off, could I have bent them
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
