Calan
DSM Wiseman
- 7,250
- 401
- Jan 16, 2007
OKC,
Oklahoma
My old crank pulley was chipped pretty bad on one edge and the rubber was out on one side more than the other, so I decided to replace it with a new one (stock).
After the swap and at idle, as I'm looking at the pulley straight on (facing the end of the crank), it looks as if the pulley is rotating slightly off center. If you know what I mean, you can see "tracers" of two different diameters. It's not much, but definitely noticeable.
Looking at it parallel to the belts, it doesn't appear to be wobbling, and the alternator belt is tracking straight. (the A/C belt is removed due to a bad compressor).
1. Is a certain amount of this normal? If so, how much... and does it go away as the balancer gets broke in?
2. How do you judge the tightness of the alternator belt? (what is too tight)
Not sure this matters, but when I reinstalled the new one (using the old bolts), the 1st bolt I started to tighten snapped off at 16lbs torque. I pulled all the bolts back out and had a look, and two of the remaining 3 showed serious signs of being over-torqued at some point in the past. The thread pitch varied and the bolts had actually yielded and stretched.
After some fun with vice grips retrieving the broken bastard, I was able to shorten some new bolts I had laying around and put it on again. I snugged up all the bolts diagonally, and then torqued them to 15lbs, then 20lbs, then 22lbs. It seemed to go on smoothly.
Should I be worried here? Can the pulley actually even be off-center or do I have more serious crank related issues?
Thanks for any help on this....
