Crankshaft pulley center bolt
blackrosenova40
398
4
Jan 12, 2006
Belle Plaine, Minnesota
I have removed the crankshaft pulley center bolt not knowing that I did not need to remove it.
There appears to be a notch where it looks like there should be a key, inside the gear thats behind the crankshaft pulley. Is there supposed to be one there?
Im in the process of removing the balance shafts.
I have a 1990 Eclipse Gsx
I think what you're talking about is just an alignment post.
The four holes in a squar pattern are bolt holes, and the little one that seems offset from the rest is for aligning the crank pulleys together.
