Lasertown
- 0
- Sep 28, 2010
portland,
Oregon
i didnt know anything about dsms when i bought my 92 laser. it has the 4g63t
the guy i bought it from told me:
it has a bigger fuel pump, doesnt remember size/brand
it has bigger injectors, doesnt remember the size. the brand is on there i can look if it matters
it has a "chipable ecu" and the stock boost gage under the tack is "a rev limiter" after getting a palm logger i found out the stock boost gage shows the knock sensor output. it jumps to around 40 knock when im in first if i dont rev the engine and let off the gas before i start. cel is 43 egr but its not on all the time i read somewhere thats a sign of different ecu?
it has a apexi safc
when i got this car it had a few minor problems, a leaking head gasket, and ran 18 psi. i blew a ring on a piston and took the head off replaced the one damaged piston and had the head rebuilt (all though it still has some valve clatter so i think the guy didnt replace the adjusters)
now i have a boost leak... i think. it only goes to around 14psi and it gets there slower then before. i made a boost leak tester but i have to turn the compressor up to 25psi to get the system to have fifteen pounds and i cant hear or find the leak. oh and now when i go wot a huge puff of light gray smoke come out of the tail pipe but only when i first hit the gas then there's no smoke keeping it in the turbo through the gears.
ok sorry i know this is long. one last thing.
i didnt touch the safc before taking the head off and i dont know if it got reset some how. it wasnt running very good after the rebuild and it showed half the rpms (im 90 percent sure it had the correct rpms when i bought it) found out it was set to 4 cyl instead of two when i set it to two it would barely run so i got a logger and tuned it to run better ( but not great considering the boost leak ) i wrote down the original numbers that were in the safc before i changed anything.
im thinking the smoke is from a crack in the turbo? could that be my boost leak that i cant hear? pieces of piston ring probably shot through my exhaust... i dont know where else they wouldve gone.
whats up with the ecu/knock sensor?
is there a way to figure out how big my fuel pump and injectors are?
Thank you for reading my post any help or insight is greatly appreciated
-Morgan
it has a apexi safc
-Morgan
