Deadly BlaZe
- 1,890
- 5
- Oct 2, 2004
Alpharetta,
Georgia
I've been having this problem for a while now, but recently it has gotten worse to the point where it's pissing me off.
A while ago, while the car warmed up, it hesitated a lot when I press the gas, even when i'm not boosting. After it warmed up, it ran fine. Recently though, it got worse. Now it happens even after it warms up. Happens when i'm not boosting, and gets worse the more i give it gas.
1. I checked for boost leaks, there are none.
2. Spark plugs are less than 10,000 miles old.
3. Have not changed the plug wires since i've owned the car (1 year)
4. Have not changed the fuel filter since i've owned the car.
5. I always used 93 octane gas.
6. There is no audible knock, but there is a little slight lifter tick that gets quieter as the car warms up.
Those are the main things I can think of that would be the problem (i've searched). Is there anything else that I should add to the list?
And also, I noticed my ECU (not sure if it's the ecu, but the noise is coming from where it's sitting) makes a beeping noise sometimes when i left off the gas. Any ideas what that could be?
