Cracked Injector -- Worry about it?
tsunari
1,031
35
Feb 12, 2003
Jessup, Maryland
All four of my injectors look pretty much like the picture below. Do I need to worry about that crack on the green cap? Can the caps be replaced?
i suggest a new injector.
Would this cause me to perhaps run lean/rich? These are stock injectors . . . so if I *DO* need to get new ones, should I go bigger?
if you go bigger you need fuel managment.
you *might* be ok cause the insulator slides over that part. worse thing that can happed is fuel is going to leak in your engine bay.
personally, id get a new injector on the trader or classifieds. i would think that'd leak.
