Crack in turbo
x427boricuaking
Feb 14, 2006
orlando, Florida
I was taking a look at my turbo an i saw a crack about an Inch maybe half an inch long and im scared to port it!! its were you connect the Exhaust Manifold.. im not sure what to do!:cry: :(
Is it on the flange or is it in the inlet? If it is on the flange I wouldn't risk porting it as it could make the crack worse or chip a bunch of material off. A picture would help out a lot though.
All 14b's probably have cracks. Unless the housing was replaced. Mine was like that, it was cracked almost all the way through. I just welded it back up, and it spools up to 14psi at around 2900 rpm with a stock exhaust.
