snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Yes, you should. But you can also put something that has equivalent weight in the drivers seat. So if you weigh 150 lbs, you can put 150 lbs worth of free weights on the driver's seat. Either or will work, but the later is probably the easier unless someone else is doing the weighing.
You also need to disconnect the sway bars before corner balancing.
