Spyder corner weights available at last!
hsk8te2006
182
Jun 9, 2007
Ann Arbor, Michigan
Hello everyone!
I searched for hours and could not find corner weights for the 2g spyder, so I had it corner weighed this morning.
The results for an almost enitrely stock 2g turbo spyder with the roof up (1/3 tank of gas, no driver, and 1 gallon of antifreeze, a flashlight, and a few jumper cables in the runk) are (in pounds):
Front left Front right
1005 907
Rear left Rear right
566 604
Total 3081
Also, it appears that the drivers weight is distributed to the corners in the following ratios: front left = 37.65%, front right = 14.19%, rear left = 35.80%, and rear right = 12.34%.
Hope this info helps some folks out!
So armed with that information, what are you going to change to achieve better handling? Thanks for sharing.
  • Wanted 6 bolt NT water pipe
    • chrisman287
