SlowUglyDSM
- 86
- 0
- May 16, 2002
Grand_Rapids_MI
Does anyone know where and how can I get my car corner weighted? Can't afford a set of corner weight scales because they cost a TON!
Anyone has some info??
Note: This feature currently requires accessing the site using the built-in Safari browser.
Anyone in the surrounding area need your car corner-weighted? It would be nice to re-coupe the money back on these expensive scales!
If you don't mind, how much was the corner weight setup? And where was it purchased?
We use the same brand scales to setup all the track cars at the shop i work in during the summer race season. Great tool to have. I need to get my car over there and work on getting the front end balanced out for the coming season, I know the rt/front needs some weight on it BAD. If i can't afford coil overs at the time, ill use shims in the sway bar mounts to adjust them.
Have you adjusted your weights and noticed any difference? You know you can actually change corner weights a BUNCH of ways, including changing toe, caster and camber. I didn't believe it until i was shown, but it will make a difference. We align all our track cars with string and a set of scales... The funny part is they track almost perfect when we're done and the wheel is centered too. but they are are a little twitchy because we set most of them up with 2* toe out in the front.
wow looks like next time i am in Stevenspoint ill look you up and weigh my car in. what are you looking at for a session?
I want to weigh my FWD! Once i get it back out.If you just want to weigh your car, i'll do that for free. that wont take very long at all.
Having cross weighed my 1g, I am amazed to see how close the R/L balance is on your car. Please tell me those numbers are w/o drivers weight added!
I have a low buck set of scales. I bought these from a friend, they are measured with bathroom scales.They are 4 to 1 of the weight on the scale. I bought them for 100.00.You can see a picture of them in Carrol Smith's book, Engineer to win page 219
