corner balance, can you feel a difference?
sillyme
151
Aug 3, 2005
seattle, Washington
i'm thinking about getting my car aligned and corner balance all in the same day by the same shop. is it worth the extra money? i have full coilovers. can you feel the difference?
Whether you'd notice depends on how far off it is now. I once had a coil-over sleeve get stuck one inch from where it was supposed to be and didn't have time to adjust the other side to match, so I did the event with totally FU'ed corners. Even if I hadn't known it, I would have noticed, since the car turned left so much better than right. (Can you say NASCAR weight-jacking?) In contrast, I've often run with one sleeve a full turn off and couldn't "feel" the difference. YMMV, of course, since your butt-dyno/butt-g-sensor may be better than mine.
- Jtoby
I run JIC coilovers that I ran for a couple months. I then corner balanced them and couldn't *feel* a difference.
feel is all relative. just like the butt-dyno. if you plan on tracking your car, i think it is worth the money. it's usually like $20-30 more for me
  • Wanted 6 bolt NT water pipe
    • chrisman287
