snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
Porting this over from my blog section to the forum before the system migration to prevent risk of loss.
I figured this would be some good information to post since I haven't made a blog in a while. I pieced together a set of DG coilovers a while ago (Nov. 2010) and am just now getting around to installing them. It's been hard knowing they're sitting in my house and not on my car for that long, but I wanted to do everything right when I put them on. This included installing SPC upper control arms (discontinued), as well as corner balancing and aligning the car. I hate taking my car in for alignments as it almost never can get up on the rack without the help of some wood planks. The last time I brought it in, the person didn't know how to drive a car with a quick spooling turbo and heavier clutch, and sent the wood planks flying backwards. I told myself that was the last time I brought it anywhere for an alignment. I had also called around to a couple race shops in the area for corner balancing quotes and they were pretty high (~$300/session including alignment). So with having my brother's car to do as well, taking it somewhere would get very pricey very quickly. I shopped around and finally decided on all of the tools I needed to corner balance and align our cars. Here is what I used:
Intercomp SW500 and scale pad case
SmartStrings
SmartCamber
HubStands (HS02)
OTC Stinger Steering Wheel Holder
To start off, any time you corner balance and align a car, the surface must be level. We followed the steps in these videos to level the garage floor. I included all 3 in the series for your viewing pleasure, as they are not all about floor leveling.
Once we got the floor level, number of tiles counted out and positions measured so they sat centered under each wheel, we drew boxes around each stack with chalk. The stacks were then moved from their boxes and the car pulled in, with each wheel centered in the box. The car was raised to prep for installing the new parts.
We installed the new DG coilovers all around, the SPC control arms up front, and disconnected both sway bars (a mandatory when corner balancing any car). The new coilover height was guessed by comparing it to the coilovers that were pulled off. The SPC ball joints were packed with more grease and the ball joint boot was zip tied on, as the metal ring that they come with is horrible. They were also run through a Bridgeport to add measurement lines to the camber adjustment area to make fine adjustments easier. The mounting stud bushings were also greased up where they contact the arm. The camber and caster settings on these were also set by a guess, to be later adjusted.
Once everything was installed, we mounted the HubStands, one side at a time. The tile stacks were put back in their chalk box and we got the scale pads out. We then ran the cables from the control unit to each pad, and tested each scale out by weighing a wheel on them (Evo 8 wheel with 245/40 Star Spec tire). After we verified they all read the same, we placed them on their tile stacks and zeroed them out to prep them for lowering the car down.
Once we got a basic weight of the car without the driver, I climbed in and my brother took the weight of the car to use for corner balancing. You need to have the driver in the car, or an equal amount of weight, or the balancing won't be done properly. Once we got the weight, we plugged it in to a spreadsheet my brother created based on a few we found on the internet and one another member on here sent me. The spreadsheet will show us how much and in what direction each corner needs to be adjusted to get the car in balance. It took us about 10-15 minutes in total and adjustments in 2 corners to get the car in balance. We thought we had done something wrong as that took hardly any time or effort, but the numbers don't lie. So we moved on to the alignment portion, which we knew would take longer.
We unboxed the SmartStrings and SmartCamber tools and assembled them. It took us a bit to figure out how to get them properly mounted and adjusted, but wasn't hard.
The steering wheel holder was also installed to keep it from moving, along with some tape between the wheel and dash to help us line it up if it did shift.
We started by measuring rear toe, which was already in. The HubStands have a built in holder for toe bars, which make measuring toe very easy.
We then measured and adjusted rear camber, which we used the SPC 73620 kits. These were very easy to install and just as easy to adjust. Once both of those measurements were in spec (also recorded on the spreadsheet), we moved on to front camber. We were fairly close with the guess, but it needed a bit of adjustment. Once we got that taken care of, we tried to check caster. However, without proper turn plates, this was a bit difficult, so we just set the SPC arms to max caster and called it done. We then moved on to front toe, which needed a lot of adjustment. Once the toe was in, we rechecked camber which had been throw out of our spec. We went back and forth a few times with front camber and toe until we finally got them both in spec.
http://www.dsmtuners.com/forums/blog_attachment.php?attachmentid=3675&d=1315415348
After everything was done, I climbed in again and Eric checked the weight to see how far out the corner balancing was after adjusting the alignment. It wasn't out much at all, which was good. He then reconnected the rear sway bar and rechecked. It had moved the weights around a bit in the rear, but nothing horrible. On to the front sway bar. This moved weights around much more, but thankfully we have adjustable sway bar end links, so we were able to remove the weight shift.
Once everything was set, we swapped the wheels back on and took a final measurement. We had forgot to account for the extra weight in the wheels, so we made a few quick adjustments. It was in spec and ready to go.
Next up is we have to figure out a bump stop solution, mainly for the front coilovers so we don't have the SPC arm self-clearance our shock towers.
Link to spreadsheet we used for corner balancing:
http://www.dsmtuners.com/forums/han...ght-scales-alignment-tools.html#post152729788
Discount coupon for HUBStands:
http://www.dsmtuners.com/forums/road-course-autocross/431694-hubstands-discount.html
SmartStrings
SmartCamber
HubStands (HS02)
