snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
I also have a 170*
Matt, what thermostat do you run? I'll be looking for one of these soon.
I also have a 170*
A 170* t-stat isn't going to effect coolant temperatures enough to have any negative effects on engine operation, even without a way to offset it with something like ECMLink. Just because the t-stat opens at 180* what DSM actually keeps 180* operating temps? Personally I can say I've never seen a 2g hold below 200* without an aftermarket t-stat, and even then its high 190*. Running a 170* t-stat vise the 180* OEM one will drop coolant temps maybe, and I stress maybe, 5* or possibly the full 10* difference which will still hold engine temps at 200* or so.
I've never heard of too low of coolant temperatures hurting a motor, gas mileage might suffer but how much? I'd rather the motor be idling stuck in traffic too cold then watching my temps climb passed 215* and possibly blow the HG.
The only downside with the coolant offset is depending on how much you alter it you will loose timing due to it. IIRC once you pass 210* the ECU starts to pull timing and by chaining the offset say 10* you ECU will always think it's 10* hotter than what it actually is.
