2G Coolant Temp Circuit Code
Tkzdsm
92
4
Sep 22, 2024
Henderson, Nevada
Hey I am battling with my car and I have one code left to get rid of before I can finally get the CEL to go away and I believe it’s a code that was thrown because of a Coolant Temperature Circuit, does anyone know about how to go about this?
I don’t know where to even start because I had a different coolant temp code for the sensor itself but I replaced that and it reads temp just fine. I am lost and I don’t want to keep it sitting for any longer.
:( any help is appreciated thank you.
Let us know when you can check and be 100% sure.
P0115 would be an issue with the Engine Coolant Sensor and not related to the dashboard gauge. #2 in the picture, #1 is for the dash gauge. I think there is another for the A/C but I can't find it right now.
The connector/wires for the ECT sensor often fail so make sure to check them all the way back to the ECU.
Yes 98.99% sure that P0115 , part 2 was the sensor I had replaced and part 1 is what I was guided by my “mechanic” neighbor and it makes sense that the connection or wires are damaged or whatnot. If the wires are damaged what should I do next?
People usually search with google and get a replace pigtail to splice in if it's just the wires on the end. Otherwise the go back as far as needed to replace them.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
